Activity Forums Creative Community Conversations Can either of the two NLE’s do this
  • Can either of the two NLE’s do this
    Posted by Vince Sanchez on April 28, 2013 at 8:54 pm
    Since this forum seems to have both the Adobe and Apple camps I’m wondering if anyone knows if this is possible. I have clips that are 60fps on a 24 timeline. This is fine. Now at some point I need a clip to play in slo mo. Is there a way setting or plugin that will allow me to force a clip to play all its frames so I get slo mo. Just using the speed change does this based on the twenty four frames of the timeline. I like high quality slo mo without having to go out to compressor.
    Thanks for any tips
    Vince Sanchez
    Intel Quad Mac 2.66
    AJA LHe
    HD link
    OSX 10.4.11
    FCP Studio 2
    Vince Sanchez replied 13 years, 4 months ago 12 Members · 16 Replies
  • 16 Replies
  • Michael Phillips
    April 28, 2013 at 9:00 pm
    PPro has the ability to “interpret clip as (frame rate)”. I am not sure of FCPx as I am not familiar with it.
    Michael
  • David Chai
    April 28, 2013 at 9:14 pm
    FCPX supports native frame rate playback, under speed, just choose conform and it’ll play back frame for frame, slow mo for 60fps in a 24fps timeline.
    David Chai
    Writer . Director
    http://www.davidchai.com
    dc@davidchai.com
  • Joseph W. bourke
    April 28, 2013 at 9:23 pm
    You may not be happy with the results you get from slomoing 24fps footage – it tends to stutter because of the smaller number of frames than 30 or 60fps. Generally, you want to use frame blending to smooth this over. Do a Google search on “frame blending in slomo” and you’ll find a number of examples illustrating the results.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Derek Andonian
    April 28, 2013 at 10:13 pm
    If you have AE you should check out the “Timewarp” effect. I don’t know how it does it but it creates beautiful slo-mo from regular footage that looks like it was shot at a higher frame rate even though it wasn’t.
    ______________________________________________
    “Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
  • Joseph W. bourke
    April 28, 2013 at 11:45 pm
    Yea, Greg –
    Timewarp is based on The Foundry’s Kronos technology, used quite a bit in high-end productions. Without getting in over my head, it basically figures out where the pixels would be if there was actually a frame in-between the existing frames. It then creates actual frames based on optical flow and motion estimation, and inserts them between the existing frames – looks like magic to me…
    Joe Bourke
    Bourke Media
  • Marcus Moore
    April 29, 2013 at 12:01 am
    I think he’s talking about the reverse. Taking 60fps in a 24p sequence.
    In his case, using the conform tool, each second of 60fps video would become 2:10 in a 24fps sequence.
  • Scott Thomas
    April 29, 2013 at 12:58 am
    I’ve used Timewarp. It can produce nice results, but it seemed to take a lot of tweeking to tune out artifacts.
    RE:VisionFX Twixtor is my usual go-to, optical flow tool.
    I think Timewarp is available inside of Premiere as well as AE.
  • Herb Sevush
    April 29, 2013 at 1:43 am
    [Scott Thomas] “RE:VisionFX Twixtor is my usual go-to, optical flow tool.”
    Agreed. Expensive but worth it.
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
  • David Chai
    April 29, 2013 at 5:12 am
    The FCPX speed tool also allows you to use Optical Flow for your retiming, and it’s pretty good too.
    David Chai
    Writer . Director
    dc@davidchai.com
  • Vince Sanchez
    April 29, 2013 at 5:48 am
    Great info everyone. I’ll be checking out the options mentioned. I’m well aware of AE and Twixtor use both. Just had a quick project I was working on and started wondering if I could just do it on the timeline with reasonable quality.
    Vince Sanchez
    Intel Quad Mac 2.66
    AJA LHe
    HD link
    OSX 10.4.11
    FCP Studio 2
