Activity › Forums › Adobe After Effects › Can “echo” be gradually increased in size?
Posted by Shane on January 5, 2007 at 2:29 amIm using AE 6.5, and under Effects -> Time, there is the echo effect. Can this effect be controlled to gradually increase in size? For example, if I have a moving object, and the echo is producing 10 echo’s behind the object, I want those 10 echos to gradually expand in size in order.
Can this be done? There are only a couple controls for the effect, so if its possible, it will have to be done some other way that im not familiar with.
ShaneSpidy2167 replied 18 years, 11 months ago 5 Members · 8 Replies -
Mylenium
January 5, 2007 at 6:30 amNo. Echo simply accumulates existing buffers. For what you are trying to do you will probably have to find some third-party plugin, though I’m not aware if such a thing exists. The way I picture it, a good place to start would be using Trapcode’s Echospace or Digital Anarchy’s
Mike Clasby
January 5, 2007 at 7:29 amWhat kind of object? If it’s an outline, say a star, you can make a star mask on a solid (comp size), then apply Render > Radio Waves.
Wave Type: Mask
Mask: Mask 1 (if it’s your mask shape)Producer Point: Animate (keyframe)this over time to get your motion path.
Wave Motion >
Frequency: Crank this up then…
Lifespan: Lower this until you get the trail you want controls fadeout).
Expansion: Adjusts how big your stars getIf you tweak the Radio Waves>Stroke>Start Width and End Width you can get solid shapes, like a solid star in my example, but when they overlap the blending looks like add, so it doesn’t look so great.
I think you should be able to do solid objects with a Particle System, like Particular maybe, but I’m not versed well enough in the particle systems.
Shane
January 5, 2007 at 2:56 pmThe object is a person running. Here are a couple screencaps showing what I am trying to recreate.
https://i94.photobucket.com/albums/l104/Vilandra06/bscap0003.jpg
https://i94.photobucket.com/albums/l104/Vilandra06/bscap0005.jpgYou can see that the trails behind him are not exactly a duplicate of him (like echo). They are more like a rough outline of his figure. They do slowly expand, and fade, but also give a slight distortion.
I talked to Aharon Rabinowitz, and he recommended watching his displacement mapping tutorial, which was very helpful, but my problem is producing these trails.
Aharon Rabinowitz
January 5, 2007 at 5:50 pmAfter you psted the question, I tried this myself – and you;re right the big problem is that yeah, it needs to get bigger and fade afterwards. Short of converting the keyed footage to an image sequence, and then frame by frame placing the position of each running frame correctly and then having each frame animate by scaling up and fading out (and this took quite a while), there’s not way I can think of to do this.
I tried it with both echo time and particlular, and with echo time you already know the issues, and with particlular, you don’t have the option of emitting one frame, and holding it, and then the next frame and holding it (which sucks becasue it has the rest of the tools you’d need, such as size over life and opacity over life). It’s frustrating becasue it;s the one option in all the possibilities for using video frames as particles that isn’t there.
Anyway with that rediculous effort (One I’m not likely to repeat), I got this:
https://allbetsareoff.com/Cow_Stuff/SuperRunCD.mov
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Shane
January 5, 2007 at 6:00 pmThat actually doesnt look all that bad, but like you said, its a long exhausting process, one that no one wants to do repeatedly. I wonder if there are any plugins out there that would do this, cause im out of ideas, unless I e-mail the studio that does this effect, and bluntly ask them, although I really dont want to do that and come across as though im trying to steal their effects.
How exactly did you get the distortion to work like that? Last time I tried, I was having some problems, and I think it was because I was using an alpha channel for the map, and I think the black needed to be a 50% grey, because the entire image was being distorted. Im assuming you probably did something similar, but had some animated noise behind the alpha, correct?
Aharon Rabinowitz
January 5, 2007 at 6:10 pmNo BG at all on the Displacement map.
And I set it to use the dsip. effect to use Brightness for distortion.
I also used the displacement map as a 25% visible image between the “actor” and BG, and set the transfer mode to Add. This helps accent the distortion without making it rediculous, and slightly tints in color like in the video clip.
Aharon Rabinowitz
Spidy2167
October 19, 2007 at 4:14 pmShane or Aharon, did ether of you get this to work? I’m very interested on this effect. I have some Volleyball footage I would like to apply this to if at all postible.
Spidy2167
October 19, 2007 at 4:14 pmShane or Aharon, did ether of you get this to work? I’m very interested on this effect. I have some Volleyball footage I would like to apply this to if at all posible.
