Activity Forums VEGAS Pro Can DVDA use 5.1 .ac3?
  • Can DVDA use 5.1 .ac3?
    Posted by Jeffrey Ellis on August 6, 2010 at 4:48 am
    I just tried importing in my finished 5.1 .ac3 file to DVDA, and it says 5.1 (stereo downmix). I need to use it as 5.1, not stereo.
    Is there a way to do this? Also, if you don’t mind my squeezing in a second question, how do I create a disc that auto-lays, and has no menus?
    Mike Kujbida replied 16 years, 1 month ago 2 Members · 3 Replies
  • Mike Kujbida
    August 6, 2010 at 11:19 am
    1. Did you set the project properties in DVDA to 5.1?
    2. File – New – Single Movie
  • Jeffrey Ellis
    August 6, 2010 at 3:31 pm
    Hi, Mike–
    Thanks for the advice. I changed the disc properties as you suggested, and also, when creating the project to reflect the 5.1 Surround. The file seems to come in well, but when I see it in the timeline, it’s still stereo. Is this just the display of an .ac3, and it will actually burn in 5.1?
  • Mike Kujbida
    August 6, 2010 at 4:23 pm
    Jeffrey, I know that DVDA will not let you preview/listen in surround mode so my guess is that your guess is correct 🙂
