Activity › Forums › Blackmagic Design › Can DL support full screen monitor with secend vga monitor?
Posted by Sun Da qing on October 16, 2006 at 3:44 amCan DL support full screen monitor with secend vga monitor?
Luke Maslen replied 19 years, 11 months ago 3 Members · 3 Replies -
Andrew Mcleod
October 16, 2006 at 4:12 amHi
Only broadcast formats are supported via Decklink devices.
SD and HD resolutions.
It is possible to output your Desktop via a Decklink device, again the format will be broadcast only.
Sun Da qing
October 16, 2006 at 4:36 amI use decklink (sdi input output only),I want to nonitor full screen video with secand lcd. If i use premiere without deklink card,I can do it .but decklink preject can not setup the secend lcd for monitor.
Luke Maslen
October 16, 2006 at 5:02 amHi,
The DeckLink card is not a graphics cards and is not designed to output to normal computer displays such as VGA displays.
The DeckLink card is a video capture and playback card and is designed to support video frame rates and resolutions via SDI or analog connections. VGA displays do not work at video frame rates such as 25 Hz and 29.97 Hz.
Regards,
Luke Maslen
Blackmagic Design
