Activity Forums Adobe After Effects Expressions Can Dan Ebberts Light Falloff work on Layers within Nested Comps?
  • Can Dan Ebberts Light Falloff work on Layers within Nested Comps?
    Posted by Eoin Ryan on October 28, 2011 at 11:05 am
    Hello,
    I’m trying to get light falloff on layers within a nested comp, it’s a succession of objects in z-space which a camera with a parented light moves past. I precomped the objects as there are dozens of them, does anyone know if it possible to get Dan’s expression to work on them by applying it to the precomp?
    I have a fairly limited understanding of expressions!
    Eoin
    Intel Mac, AE CS4
    Eoin Ryan replied 14 years, 10 months ago 2 Members · 4 Replies
  • Eoin Ryan
    October 28, 2011 at 11:18 am
    Also, I’ve just realised this expression doesn’t work when you move the light past the object, only when you move the layer past the light. It’s probably a big ask but does anyone have a solution for this as well?!
    Eoin
  • Dan Ebberts
    October 28, 2011 at 8:25 pm
    Assuming that the comp with the light is named “Main” and that your sub-comp is a 3D layer in the main comp with Collapse Transformations turned on, this should work:
    M = comp("Main");
    L1 = M.layer("Light 1");
    decay = .005;
    noFalloff = 200;
    P2 = toWorld(anchorPoint);
    L2 = M.layer(thisComp.name);
    d = length(L1.toWorld([0,0,0]),L2.toWorld(P2));
    if (d < noFalloff){
    value;
    }else{
    value/Math.exp((d - noFalloff)*decay);
    A better solution is probably to upgrade to AE CS5.5, which has built-in light falloff.
    Dan
  • Dan Ebberts
    October 28, 2011 at 8:27 pm
    What’s the issue, exactly? What behavior were you expecting?
    Dan
  • Eoin Ryan
    October 31, 2011 at 11:07 am
    Thanks for that Dan, it worked!
    Yes I think an upgrade to CS5 might be in order but this will do nicely for now,
    Thanks again,
    Eoin
