Can Compressor keep Timecode as passthrough when transcoding to ProRes LT?
I have recently discovered Digital Rebellion’s QT Edit…which allows me to batch add TC to my Nikon’s D7000 clips. (Nikon isn’t as cool as Canon with their L&T plugin preserving TC metadata). Before now, although I could set the camera to time-of-day and batch rename with Adobe Bridge to make the name of each clip be the time-of-day, my timecode would still only start at 00:00:00.
With QT Edit, I can batch all of my clips from an event that I shoot and give them actual TC (with the “file creation” time, thus giving me time-of-day TC). However, this only seems to work on the original H.264 files. As I am working in Final Cut 7, these are obviously not editable before transcoding. If I bring the H.264 files into FCP, the TC that I generated is correct (starting TC, length of clip, etc.) So I know that QT Edit is at least working correctly.
Here’s my problem….
I normally use Compressor (via droplets) to transcode my footage (usually to ProRes LT). But, for some reason, Compressor decides that it wants to alter my timecode!?!?
Example:
My clip was created (recorded) at 8/26/11 4:22 PM. The batch rename from Bridge names it “082611_162234”. If I bring the h.264 clip in to FCP directly, it shows the correct timecode (again, obviously not editable). But, for some reason, Compressor seems to think that the TC start time is “01:08:11:07”. That’s not even CLOSE!
So, my question is,
Is there a way to set Compressor to have pass-through Time Code? .
