Activity Forums Apple Final Cut Pro Legacy Can Capture footage at 24 but not 30
  • Can Capture footage at 24 but not 30
    Posted by Airplanesteve on May 30, 2006 at 6:42 pm
    I’m trying to capture footage from my varicam shoot recorded at 30 fps with a system frequency of 59.94. I try and load the footage via the konaLHE and have it remove the duplicate frames. All seems fine until I go to actually capture the footage and then final cut tells me there is no video. If I try this with test footage shot with the same camera and same settings with the frame rate at 24 it works fine. Even if I try and capture the 24p at 29.97 or 30 fps it loads it fine. But as soon as I try footage recorded at 30fps it goes dark. doesn’t matter what frame rate I select (29.97 or 30) it just won’t work. Can anyone give me some ideas on what to chase down? Thanks in advance. Steve Flynn
    steve at airthis
    Airplanesteve replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
