Activity Forums Maxon Cinema 4D Can C4D do 29.97 fps?
  • Can C4D do 29.97 fps?
    Posted by Shawn Marshall on August 9, 2010 at 10:39 pm
    Hi:
    I’m unclear as to whether C4D can do a true 29.97 frame rate. If I try to input 29.97 into the Project Settings Frame Rate dialog it truncates to 29. The Render Settings indicate a 29.97 frame rate, though the resulting image sequence shows up as 30fps. I don’t know whether it’s really doing 29.97 or 30fps.
    I’m working on a virtual set, tracking greenscreen footage in Syntheyes, exporting as a Lightwave scene and importing that into C4D. The video is 1920×1080, 29.97 fps. The track looks good in Syntheyes, but looks a little off in C4D, and I’m wondering if that’s due to a frame rate mismatch.
    Thanks.
    Shawn Marshall
    Marshall Arts Motion Graphics
    Shawn Marshall replied 16 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 10, 2010 at 5:17 am
    The answer is no. Usually it’s not noticeable but if it is the best you can do is time stretch the difference in post.
  • Shawn Marshall
    August 10, 2010 at 7:29 am
    Thanks for the reply.
    I’ll do everything at 30fps like I do in Lightwave. I think my tracking problems might have been due to a bad track in Syntheyes, which I think I’ve corrected.
    Shawn
