Activity › Forums › Blackmagic Design › Can Broadcast Converter cross frame rates?
  • Terence Curren
    August 20, 2008 at 9:40 pm
    And, does it handled embedded audio?
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Callum Mclay
    August 21, 2008 at 4:40 pm
    Hi Terrence
    Broadcast converter is going to be a straight signal converter, allowing you to go from analogue to digital, and digital to analogue simultaneously, or do a digital to digital conversion for SDI to HDMI.
    So which ever resolution signal you put into the Broadcast converter, you will get the same resolution signal out, only in a different format.
    Effectively, you will be getting all the functions of the mini converters in one unit. Currently none of the mini converters or Broadcast converter do a standards conversion.
    Hope this helps.
    Callum McLay
    Technical Support Consultant
    Blackmagic Design EMEA
