Can BCC7 do this?
Posted by Stephen Mann on October 14, 2011 at 1:04 pmUsing Sony Vegas Pro 10/64 and BCC7
I have a client who wants me to draw a line on a static image of a wall showing where pipes are under the wallboard. I am new to BCC7 but I am not sure of the best way to do this. Any tips would be appreciated.Steve Mann
MannMade Digital Video
http://www.mmdv.comPeter Mcauley replied 14 years, 11 months ago 2 Members · 5 Replies -
Peter Mcauley
October 14, 2011 at 1:51 pmHi,
Yes, you can use the BCC Extruded Spline to do that.
Add a video track above the static image and add a piece of media to that track to which you apply the BCC Extruded Spline. Then, in the filter control panel, set the Path Type pop-up to Line and reduce the Extrusion and Bevel amount to the values that look good to your eye.
Cheers,
Peter.
Stephen Mann
October 14, 2011 at 4:16 pmThanks Peter – this gives me another reason to learn more of BCC7 capabilities.
Steve Mann
http://www.mmdv.com -
Stephen Mann
October 14, 2011 at 11:50 pmWell, after spending an hour trying to follow John’s tutorial on extruded spline…
In John’s tut, when you load the FX on a blank event, you see the rectangle by default. When I do it, I get a black preview.Then, I realize that my video card won’t do extruded anything.
I have a new editing PC that I haven’t migrated my programs to, so what’s the proper procedure with BCC7? Is it like Adobe stuff where I have to unregister on one machine then install then re-register on the new one?
I can’t find anything on this in the forums or documentation.
TIA
Steve MannSteve Mann
Stephen Mann
October 16, 2011 at 2:22 pmI built a new editing workstation to replace my aging quad-core. But, when I installed BCC7 trial on it, then open Vegas, and there’s no BCC effects.
I tried restarting, just in case. No BCC7
I removed and reinstalled, no BCC7 in Vegas.Of course, if there’s no BCC7 trial in Vegas, I can’t navigate the byzantine unlock process to use the purchased version.
SteveSteve Mann
Peter Mcauley
October 17, 2011 at 12:58 pmHi Steve,
Sounds like you need one of our techs to assist you with getting the software installed on your system. Please send us your contact information via email at support@borisfx.com and please cc me (peterm@borisfx.com) on the message, and someone from here will get in touch with you to help sort this out. Please include in your message the best way to contact you (phone or email) and the best time for that.
Cheers,
Peter.
