Activity Forums Avid Media Composer Can Avid Xpress Pro HD capture NTSC DV?
  • Can Avid Xpress Pro HD capture NTSC DV?
    Posted by N1gooner on February 12, 2006 at 5:51 pm
    I have borrowed an NTSC video camera so I can capture my NTSC video tapes (I live in Europe you see) but I cant seem to be able to see or find an NTSC setting which will allow me to capture my tapes. Am I wrong in assuming I can do this with Avid Xpress Pro HD?
    Wes Plate replied 20 years, 7 months ago 3 Members · 3 Replies
  • Valerie Shoaps
    February 12, 2006 at 6:58 pm
    Check your project settings – you probably have it set for PAL.
    Valerie
  • N1gooner
    February 12, 2006 at 11:55 pm
    In the general tab under the preferences, it says my current project is PAL.
    When I try and change the format, (edit-preferences-format-project type) there are only 2 options; 25p PAL and 1080p PAL.
    When I go to log and capture it wont let me select the video.
    Any suggestions?
  • Wes Plate
    February 18, 2006 at 1:15 am
    You’ve no doubt figured this out by now, but you have to create a new project, and choose to create an NTSC project.
    — Wes Plate
    Automatic Duck
