Activity › Forums › Adobe Premiere Pro › can audio be split to L & R channels after capture?
  • can audio be split to L & R channels after capture?
    Posted by Nelson May on November 25, 2009 at 9:20 pm
    I am working in CS4 and don’t use it that much. I am an FCP guy, but am using CS4 on this project. I captured DV with 2 channels of audio. One of the talent had a turtle neck and it was hard to place a lav mic. She was off axis a bit. All I need to do is bump up her audio a few db to match the db level of the male voice.
    How do I manipulate L and R audio tracks in CS4? I am at a loss.
    MBP 2.4GHz 4MB RAM, 30″cine, MAC PRO 2.6 8 core 6GB RAM, Mbox, Neumann TLM-103, FCP HD 7. Pro Tools 8, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
    Sebastian Plamadeala replied 16 years, 9 months ago 4 Members · 4 Replies
  • Jeff Pulera
    November 27, 2009 at 9:11 pm
    Right-click the video clip on timeline and select “Unlink”, then select just the audio clip below and COPY, then PASTE to a lower track and line up with original so it is in sync.
    In the Premiere AUDIO FILTERS, find FILL LEFT and FILL RIGHT, and apply one to each of the audio clips, resulting in one audio clip having stereo audio of just the left channel, and the other having the right, then you can adjust volume and/or filters individually.
    Jeff Pulera
    Safe Harbor Computers
  • Ann Bens
    November 27, 2009 at 11:32 pm
    Another way is to select clip in the project window then go to Clip/Audio Options/BreakOut To Mono. This wil give you a seperate left and right channel.
  • Nelson May
    November 30, 2009 at 1:10 am
    Thanks and these methods will work, but I am working on a time crunch. Having to go back and re-track audio is a waste of a few hours. Can I separate audio into their perspective L and R tracks during capture?
    If not, I will capture in FCP and import the file to Premier and work.
  • Sebastian Plamadeala
    December 24, 2009 at 9:57 pm
    During capture there is no way, but the way Jeff and Ann suggest doesn’t take hours, just takes seconds to do. Even after hundreds of cuts.
    Even if you capture in final cut, you get the same file in premiere pro… Its just the way premiere imports files.
    Merry Christmas,
