Activity › Forums › VEGAS Pro › Can audio be compressed?
  • Can audio be compressed?
    Posted by Linda O’connell on June 11, 2009 at 11:10 pm
    I am transferring over 9 hours of audio reel to reel to cd.
    I believe most cds only hold 60 minutes? Is there a way to “compress” audio like you can for video to fit more than 60 minutes on a cd?
    Or does anyone have any other ideas/ways to do this?
    Thanks in advance.
    Linda O’connell replied 17 years, 3 months ago 2 Members · 2 Replies
  • Rob Strobbe
    June 11, 2009 at 11:18 pm
    Actually, most CDs are about 72 minutes.
    But, no, you cannot compress it in order to get more — assuming you want it to play in a standard CD player. A standard CD’s audio is fixed at 44.1KHz and 16-bit stereo — it holds what it holds, and that’s what it holds. 😉
    You could stick the files on a Vegas timeline and change the playback rate, but you won’t only be able to “compress” it so much before the audio will be distorted. (Vegas is able to change the length of audio without affecting the pitch, but naturally there is a point at which the speaker is going to fast for anyone to understand.)
    The other option is to encode to MP3 and put those on a data CD instead of a standard audio CD. Many CD players (esp. car CD players) will be able to play on it, but not all of them.
    Rob
  • Linda O’connell
    June 12, 2009 at 2:23 am
    Thanks Rob, that is what I was thinking. But every time I learn something new, I realize there is so much I don’t know!
    Each reel holds just about 1 hr 4 minutes so I will probably just stick to the 1 reel/cd. (Some of these reels are two sided also!)
    The reels are really cool. The man I am doing it for, mother, used to sing on a radio show in the 1960’s. A lot of big band stuff. He is really excited to hear her on it.
