Can anyone reproduce this Ron Scott tutorial in Vegas Pro 15?
John Bolton replied 8 years, 3 months ago 4 Members · 26 Replies
Allan Finney
May 9, 2018 at 6:19 pmOk, got the version numbers screwed up. I’m on version 321 which as far as I know is the latest version. I’m thinking that there’s some “preferences” settings or something that is preventing this or????
I just loaded your file “as is” and it’s obviously working for you but there’s something here that’s screwing this up somehow. But thanks for the grand effort – very much appreciated!!!
John Bolton
May 9, 2018 at 8:14 pmHi Allan, it’s a bit weird. You could also try my first test which was just use any Background picture for the background and then add a cut out object ( maybe a person ) to that background picture ( I used Photoshop ) and call it the Action picture
Then using those 2 pictures… track 2 for the basic Background and track 4 & 5 for the one you have added an object….see if you can get that to work. Don’t use and video media.
Also, if you can send me a snippet of the media you are using then I can also check it here
Regards
John Bolton
May 9, 2018 at 8:16 pmOps I meant tracks 3 & 5 for the action…….but I guess you spotted that 🙂
Pete Baratta
May 19, 2018 at 9:50 amHi guys,
Just reading through the thread and thought I’d give it a try. I used some animation instead of text
and it worked out fine…gotta pay attention to the instructions though.It’s only about 10 sec long but I have no idea how to upload it. It’s a m2t file about 30 mgs.
I’m using v13.
Pete -
Pete Baratta
May 19, 2018 at 10:55 amThink I figured it out. Here’s the link.
The mouse is substituted for text.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Bolton
May 19, 2018 at 5:07 pmHi Pete.. I also found it works easier with NON text. As you say, it is a bit tricky but after some experimenting you can work out what affects the layers with the media you have added for the ” Behind ” requirement.
I also did two” Behind” layers just to see if it was possible and it sort of worked out OK.. The lighting on the Video Media is a bit critical but animation is a bit more controlled..
Anyway…Nice one
Regards
Allan Finney
May 21, 2018 at 7:04 pmJohn, Pete – thanks for giving this a go. I’ve never been able to get it to work and as far as I can see I’m following the instructions to the letter. Maybe it’s the footage I’m using? I’ve tried it with a couple of different shots but I’m at a loss – can you get this clip to work?
James Ollick
May 21, 2018 at 10:04 pmAllan, I downloaded the rar file and tried it as I also have the latest version of VP15. It did not work until I played with the track FX on track 2. I played with the Levels Input Start and Input End, then it worked. See my settings below.
James Ollick
Allan Finney
May 21, 2018 at 10:34 pmThanks James, I’ll give it a try again – seems awfully fiddly – I uploaded a file as well in a previous post with my raw footage – can’t get that to work either. Frustrating………….
