Activity Forums Adobe After Effects Can anyone explain the process of this animation technique?
  • Can anyone explain the process of this animation technique?
    Posted by Clyde Finn on February 26, 2014 at 3:48 am
    I’ve done a bit of research into trying to figure out this animation technique, but unfortunately haven’t had any luck finding any detailed explanations. Here are a couple of examples:
    https://vimeo.com/31735213
    https://www.youtube.com/watch?v=fVE6WF0wFa0
    https://www.youtube.com/watch?v=6JbyJFZ-r14
    This is my first year of working with after effects so I’m relatively new to learning all that this program is capable of. If anyone can explain this process of animation to me I will be eternally grateful. I hope to learn this in time to do my senior project in the next 2 months.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jason Jantzen replied 12 years, 2 months ago 3 Members · 4 Replies
  • Todd Kopriva
    February 26, 2014 at 7:09 am
    There are a lot of things going on in that video. Which exact parts are you wondering about?
    Start here to learn After Effects:
    https://adobe.ly/AE_basics
    After Effects team blog
  • Jason Jantzen
    February 26, 2014 at 6:06 pm
    Very similar to rotoscoping, you would basically paint over the video frames with the graphics you want to animate and do them frame by frame, except maybe half the frame rate, so painting every other frame or every 3 frames, whichever you prefer. For the graphics that aren’t painting over video frames, you could maybe get away with some turbulent noise effects and time posterization to get the frame by frame look. Turbulent noise can displace the alpha channel of your graphic and make it look wiggly. Time posterization essentially reduces the frame rate.
    Jason Jantzen
    vimeo.com/jasonj
  • Clyde Finn
    February 27, 2014 at 12:45 am
    I was wondering about the hand drawn illustrating and animating in particular
  • Jason Jantzen
    February 27, 2014 at 2:28 am
    Try this – https://lmgtfy.com/?q=painting+over+video+after+effects
    Jason Jantzen
    vimeo.com/jasonj
