Can any Quickeys User Help me?
Hi list, I am trying to use QuicKeys to automate an often used repetitive action in FCP.
What I am trying to accomplish is to 1. Mark an in-point in a secondary (not the main) viewer 2. step forward three frames 3. Mark an outpoint. And pop that clip in the timeline at the playhead. Here is where I am coming undone.
As I said, I would like to insert the marked clip at the playhead in the timeline. As you know, FCP shortcuts are set up to work only in the main viewer and operate only on the marked clip in the main viewer.
What I’m trying to accomplish is to get the selected/marked clip from whichever viewer is active and get that clip in to the timeline at the playhead. How I would manually accomplish this is by dropping said clip either directly into the timeline at the playhead OR dragging it over the area on the right of the screen where (translucent popup) options appear for dropping the clip I’m dragging into the timeline.
I am not sure how I can translate this action into a short cut Quickeys can follow. None of the prescribed paths offered in QuicKeys seem to give me the option of recording this action. I can program the entire action with Final Cut’s menu commands through QuicKeys to the point of marking the in-point, moving forward three frames, then marking the outpoint, but this last step of inserting the marked clip from a secondary viewer into the timeline has me stumped.
Would anyone know how I might be able to accomplish the final action of what I’m trying to achieve above.
I would be very grateful (and so would my rotator cuff 😕 ) if anyone could shed some light on the final part of the puzzle.
Warmest,
Kevin
