Activity Forums AJA Video Systems Can Aja Kona lhe works with Samsung monitor?
  • Can Aja Kona lhe works with Samsung monitor?
    Posted by Bim Ajadi on April 12, 2011 at 12:46 am
    Hi
    I’m wondering if the AJA Kona Lhe card works with Samsung monitor that i’m using- SyncMaster P2270HD? I have the leads that comes with Kona-LHe Standard AV Breakout cable but noticed there’s no suitable connection with the cable to the monitor? Would I need to get adaptor?
    Any advice here would be most appreciated as I’ve got the capture card with a Breakout Box and mac pro 8 core 2×2.4Ghz Quad-Core Intel.
    Bim
    Bim Ajadi replied 15 years, 4 months ago 3 Members · 5 Replies
  • Fred Connors jr.
    April 12, 2011 at 1:00 pm
    What are the input options of the SyncMaster P2270HD?
    What are the outputs options of the Kona-LHe
    Now if you have a match your ready to go.
    If you don’t have a match then you will need to find some kind of converter.
    AJA makes all kinds of HD-SDI to XXZZY converter.
    The Troupe – Modern Media Design & Production
  • Bim Ajadi
    April 18, 2011 at 3:19 pm
    Hi
    Sorry for late respond…
    Monitor input –
    Signal Input
    Video SignalAnalog RGB, DVI, HDMI, Component , SCART, TV (Digital TV / Analog TV)
    Sync. SignalSeparate H / V, Composite
    ConnectorD – sub, DVI – D, HDMI, Component, SCART, DTV Tuner, Optical Out, Audio In, Headphone Out, CI – Slot
    AJA ouput –
    Digital:
    SD and HD-SDI, SMPTE-259/292/296
    Analog:
    Composite/S-Video (Y/C):
    NTSC, NTSCJ, PAL
    12-bit D/A, 8x oversampling
    SD Component:
    SMPTE/EBU N10, Betacam 525 line, Betacam 525J, RGB
    HD Component:
    YPbPr, RGB
    12-bit D/A, 2x oversampling
    So what sort of converter do i need to go with Samsung monitor?
    Is there online video tutorial to demonstrate how to install Aja card as I’m anxious i get it wrong??
    Cheers again
    Bim
  • Fred Connors jr.
    April 19, 2011 at 1:08 pm
    I would suggest an SDI to HDMI converter
    https://www.aja.com/products/converters/
  • Gerry Lawson
    April 26, 2011 at 6:54 pm
    Hi Bim,
    It seems to me that all you would need are 3 BNC to RCA adapters.
    The breakout cable from the Kona LHE has 3 BNC Male connectors for component output. Your monitor will have 3 RCA female connectors for the component input. The breakout cable may not be long enough to reach your monitor.
    You probably need 3 BNC(Female) to RCA(Female) adapters. The link is just an example – I’ve never ordered from them.
    https://www.pacificcable.com/Picture_Page.asp?DataName=RFA-8391
    Then any component RCA patch cable to connect to your monitor.
    https://www.pacificcable.com/Picture_Page.asp?DataName=254-506X
    Good luck,
    gerry
  • Bim Ajadi
    April 26, 2011 at 10:42 pm
    Hi Gary
    Many thanks for this. Does that mean I wont need to buy the AJA Video Hi5 HD-SDI/SDI To HDMI Video & Audio Converter?
    Cheers again
    Bim
