Activity Forums Adobe After Effects Can AE read from a database (or a simple textfile) ?
  • Dan Ebberts
    January 11, 2006 at 5:47 pm
    It would be fairly easy with a script. You can’t do it with just an expression though.
    Dan
  • Dapaus
    January 12, 2006 at 12:56 pm
    Ok, thanks! And how could such a script look like?
  • Dan Ebberts
    January 12, 2006 at 2:32 pm
    In general, it would involve prompting the user to navigate to your text file, setting up a loop to read each line of the file until the end-of-file is reached, converting the text to floating point and creating a new position keyframe at the appropriate time (which, from your description, sounds like it would be the same as the line number).
    It’s fairly straight-forward if you have some scripting exprerience. Unfortunately the learning curve for scripting is quite a bit steeper than it is for expressions.
    Dan
