Activity Forums Apple Final Cut Pro Legacy Can a PC read Quicktime files off a Mac formatted portable HD??
  • Can a PC read Quicktime files off a Mac formatted portable HD??
    Posted by Jason Flor on April 10, 2012 at 9:40 pm
    The Director I’m working with wants to screen the QuickTime files I have made and put on a MAC formatted portable hard drive. He has a PC Laptop with Quicktime Pro7 for Windows.. Will he be able to screen the QT’s using the portable drive?
    Michael Gissing replied 14 years, 5 months ago 3 Members · 4 Replies
  • Michael Gissing
    April 10, 2012 at 9:45 pm
    Yep. All he needs to do is install MacDrive software on the PC to read the Mac formatted drive. Also make sure he has an up to date version of quicktime so that he has Prores codecs if that is what you are using. H264 will work and be easy to play of a USB drive.
    ProRes will not play smoothly off a USB drive depending on frame size and frame rate. You can test the drive speed with free speed test software from AJA or Blackmagic.
  • Shane Ross
    April 10, 2012 at 10:04 pm
    HDV, DVCPRO HD, XDCAM….they will have issues unless they get special decoders.
    Shane
    Little Frog Post
  • Jason Flor
    April 10, 2012 at 10:27 pm
    The Quicktimes are RED camera files Transcoded to Prores 4444.
  • Michael Gissing
    April 10, 2012 at 10:45 pm
    The drive will need esata for that codec. I presume the frame size is 2k or at least 1920. Not sure if the Prores codecs for Win includes 4444.
