Activity › Forums › Avid Media Composer › Can a non-drop clip be changed to drop frame on import?
  • Michael Phillips
    July 31, 2014 at 6:51 pm
    I don’t know about accidentally as the import, or AMA link reads the timecode and gender from the file. If you need to change it, you can use “modify”. May not work on AMA linked clips till you transcode.
    Michael
  • Scott Davis
    July 31, 2014 at 7:01 pm
    Thanks Michael, I didn’t think that I could change it on import. Wanted to double check though.
    Scott Davis
    View Scott Davis's profile on LinkedIn
