  • Posted by Don6of7 on September 29, 2007 at 10:58 am
    I’m using the HDV 1080 60i easy setup option in Final Cut Pro 6 and trying to capture from my Canon XH A1. The problem is that I get frequent time code breaks even though there are none on the tape. I have the break up clips on rec start/stop option toggled off.
    Is there a specific capture setting I need to use for my camera?
    Is there someway I can turn off FCP timecode or find a work around?
    Chris Poisson replied 18 years, 11 months ago 4 Members · 4 Replies
  • Walter Biscardi
    September 29, 2007 at 11:00 am
    [don6of7] “Is there someway I can turn off FCP timecode or find a work around?”
    User Preferences > On Timecode Break > Warn After Capture
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Chris Poisson
    September 29, 2007 at 1:50 pm
    In the HDV capture window there’s a new clip on timecode break check box, turn it off.
    Have a wonderful day.
  • Andre D’elena
    September 29, 2007 at 8:57 pm
    You could try using the Uncontrolled Device profile in the Log & Capture > Capture Settings tab. Just a thought.
  • Chris Poisson
    September 30, 2007 at 12:44 pm
    There is no non-controllable device option with FireWire capture on HDV, it is VERY persnickety about settings to even get the damn window to launch properly. No can do, sorry.
