Activity › Forums › Apple Final Cut Pro Legacy › Can
Posted by Tania Dorado on January 17, 2007 at 10:20 am
Please help! I
Rafael Amador replied 19 years, 8 months ago 3 Members · 2 Replies -
Rob Forsythe
January 17, 2007 at 2:53 pmYou don’t HAVE to “Print to Video” if you’re having problems.
You need to fully RENDER the timeline.
Then, you can simply hit “record” on the DV device and then just PLAY the timeline.This list contains virtually everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.
d. Being able to capture from a FW device.If working this list doesn’t cure the problem… you may have a serious PROBLEM!
Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen or “pushed into” other windows.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Make sure you have chosen FW output for A/V:
Final Cut Pro (menu) > Audio/Video Settings… >
Video Playback: Apple FireWire NTSC (720 x480)
Audio Playback: FireWire DV
11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
15. Important: Quit FCP, then Restart FCP.
16. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729If you have “lost” your entire FW connection between the Mac and the device, go HERE:
https://docs.info.apple.com/article.html?artnum=301852>Then, start again at my “step 1” above.
Rafael Amador
January 17, 2007 at 4:03 pmHola lolala,
If you can download the film from your canara this mean that your Firewier conexion works well and your camera play OK. But if you can not print to video your camera may be not set up conveniently. I’m sorry I can not tell you for sure about the JVC or the Canon, but the Sony’s they have a set-up that allow to capture but don’t let you print to video. In the SONY DVCam DSR-PD170 (and in the SONY VTR DSR-11 as well), in the VTR SET MENU, you’ve got a set-up A/V-DV OUT (or DV EE OUT) this you must set it to OFF if you want the video from your computer reach the camera.
Conect your camara through the Firewire and set it in VCR mode before to open FC. Once you have open FC go to VIEW>Video play-back> Firewire (PAL OR NTSC up to the camara). Then when you play something in FC you must get the image in your camara viewfinder and you can procede to print to video.
Salud,
Rafael
