Activity Forums Apple Final Cut Pro Legacy Can 60i be made to “match” 24P?
  • Can 60i be made to “match” 24P?
    Posted by Ned Miller on January 1, 2010 at 12:13 am
    I did a search of both forums and found nothing, I consider this a bigger challenge than a Basics question. Here goes:
    I was using an HVX200 and had set and SAVED a scene file for 480/24P and shot a tape with it (no shutter), then when I changed the battery the scene file setting did not save (perhaps the internal lithium is dead or I hit a SW button?) and reverted the camera to 480/60i. I shot awhile in that mode until I noticed it and changed back to 24P.
    My question is: Is there a filter or technique that will make the 60i footage look more like the 24P footage? The final viewing will be on DVD.
    Thank you!
    Paul Ray replied 16 years, 7 months ago 6 Members · 5 Replies
  • Steve Eisen
    January 1, 2010 at 12:28 am
    Happy New Year Ned.
    Check out Nattress plug-ins. Nattress.com
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Michael Sacci
    January 1, 2010 at 2:39 am
    You can also give Compressor a try.
    Change Video Frame rate to custom 23.976 (not 24) under the encoder tab then,
    Turn on Frame Control
    Output Fields: Progressive
    Deinterlace: Best
    The 2 sliders are for resizing so leave them alone.
    Test short segments
    give it a shot since this is free to try, be for warned anything that does a good job with take some time to encode, heavy lifting here.
    Red Giant also has Magic Bullet Frames, we use to use the 24p convert years ago and it did a very good job, have not used the new version.
  • Ben Holmes
    January 2, 2010 at 10:54 am
    Can’t check, but doesn’t Cinema Tools conform 60i to 24p? I’d be suprised if it didn’t….
    Note that if your footage lacks the ‘progressive’ look when converted, you could use one of the many film filters to achieve it (such as Nattress) or (quick and dirty) just de-interlace it…
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Rafael Amador
    January 2, 2010 at 11:12 am
    CinemaTools is supposed for progressive footage. if you Conform some interlaced footage as progressive you will end up with something very ugly.
    rafael
    http://www.nagavideo.com
  • Paul Ray
    February 19, 2010 at 9:14 pm
    I just tried this technique in compressor, and the footage came out looking choppy. Any suggestions as to what I’m doing wrong?
