Activity Forums Storage & Archiving Can 2 x Lacie 4big Quadra 12TB be Combined into 1 larger Raid System
  • Can 2 x Lacie 4big Quadra 12TB be Combined into 1 larger Raid System
    Posted by Opie Sayner-hassall on August 1, 2013 at 3:59 am
    I have just purchased a 2nd Lacie 12TB 4big Quadra external storage drive.
    Is it possible to combine both drives into 1 bigger storage raid system?
    Regards,
    Opie
    Alex Gerulaitis replied 13 years, 1 month ago 2 Members · 3 Replies
  • Alex Gerulaitis
    August 1, 2013 at 6:33 am
    Yes, with spanning or striping in either OSX or Windows. What system (hardware, OS) are you using?
  • Opie Sayner-hassall
    August 2, 2013 at 2:52 am
    Mac Pro, Quad-Core Intel Xeon – 2.8GHz
    Mac OS X 10.7.5
    Do you know of any tutorials or blogs that I can learn how spanning and stripping process?
    Thanks for verifying that it can be done.
    Opie
  • Alex Gerulaitis
    August 2, 2013 at 11:53 pm
    I thought I replied but maybe my post is still sitting in the moderation queue…
    First, a correction: RAIDing removable / portable drives is neither recommended nor supported, so you may not be able to RAID two of your Quadras together. I completely blanked out on this when responding. In general, the device must appear to the system as “fixed” in order to be a part of a RAID set.
    Here is one relevant article:
    https://support.apple.com/kb/PH5834
