  • Posted by Alejandro Maldonado on June 9, 2006 at 12:29 am
    Hi everyone! this is my first post here, if only it was for something good…
    Everytime I try to install the drivers (5.6 x64) for HD Extreme I get a blue screen stating:
    “DRIVER_IRQL_NOT_LESS_OR_EQUAL”
    ***STOP: 0x0000000000000048
    0x0000000000000002
    0x0000000000000000
    0xFFFFFADF8D35A543
    ***DECKLINK.SYS – ADDRESS FFFFFADF8D35A543 BASE AT FFFFFADF8D346000, DATESTAMP 447D2CFA
    It happens when windows tries to install the hardware (only the BMD display driver the audio driver installs perfectly fine) after I
    Newjack replied 20 years, 3 months ago 4 Members · 4 Replies
  • Andrew Mcleod
    June 9, 2006 at 7:56 am
    Hi
    Currently we are working on this issue and should have a driver to address this issue by next week.
    In the mean time if you say no not at this time to the installation of the decklink display you will be able to continue to work with After Effects, Premiere Pro etc
    Desktop display will be the only element not present.
    To stop the message from reappearing – disable the device in the device manager.
    any further questions email – pcsupport@blackmagic-design.com.
    Andrew McLeod
    Blackmagic Design
  • Alejandro Maldonado
    June 9, 2006 at 1:54 pm
    Thanks a lot for the quick reply, I
  • Miles Blow
    June 10, 2006 at 12:16 am
    Hi Andrew
    Do you think this display driver issue is common to both the a8n32 aswell as the k8we opteron? I thought the k8we was way different as it had two pci-express chipsets.
    thanks
    miles
  • Newjack
    June 15, 2006 at 10:00 pm
    Hi,all
    Heres BMD solution:
    Please have a look at, too: https://www.blackmagic-design.com/support/detail.asp?techID=160
    The short version is that customers should not use more than 3 GB of
    RAM with 64-bit versions of Windows and that most customers should
    continue using 32-bit versions of Windows. The DeckLink and Multibridge
    Minimum System Requirements support pages have also been updated to
    advise a maximum of 3 GB of RAM.
    Having said that, we would urge most customers to continue using 32-bit
    versions of Windows as the 64-bit versions are really only of use to
    some developers. Applications such as Premiere Pro and After Effects
    are 32-bit applications and will run more slowly on a 64-bit version of
    Windows and there are absolutely no benefits to doing this.
    We regard the use of 64-bit versions of Windows, with commercial video
    software and Blackmagic hardware, as something to avoid as there are no
    benefits and in fact there is likely to be performance degradation. The
    only early adopters who should need to use 64-bit versions of Windows
    will be some developers.
    The reason for releasing 64-bit Windows versions of our drivers was to
    make some developers happy. However we are hearing from customers who
    have mistakenly assumed that there is something “better” about the
    64-bit versions of Windows and are now running in to problems with lack
    of support, for mainstream video applications, and also instability
    with more than 3 GB of RAM.
    We tried it with 3GB and now it works perfectly – and I think BMD will work on it. Because there are a lot of compositors outside who needs more than 3GB.
    Cheers,
    Oliver
