Activity Forums Adobe After Effects camera zoom help
  • camera zoom help
    Posted by Bdazzled on March 21, 2007 at 6:56 pm
    I have a map with newspaper layers placed through out the map. My problem is when i go from a birds eye view of the map and zoom into one of the newspaper layers it seems that the newspaper layer move a little bit across the map. I do not have any key frames set on the layers just on the camera. So why does this happen.
    Darby Edelen replied 19 years, 6 months ago 2 Members · 1 Reply
  • Darby Edelen
    March 24, 2007 at 11:18 pm
    I’m guessing this is you experiencing parallax (a natural phenomenon) inside the virtual world of After Effects, but I could be wrong. If all of the layers are 3D layers (as it sounds like they are if you’re using a camera) are the newspaper layers close to the map layer in Z-space (depth, do they have a similar Z position value)? Also, just to get our terminology entirely clarified, are you only zooming (animating the zoom value) or dollying/tracking/panning (animating the position/point of interest/rotation values) as well?
