Activity › Forums › Adobe After Effects Expressions › Camera Z Position move faster on a beat
  • Camera Z Position move faster on a beat
    Posted by Ole Peters on August 8, 2015 at 4:54 pm
    Hello,
    I’m looking for an expression, which let’s the camera move faster on the Z axis when a beat/peak of the Audio Amplitude in the composition “Music” appears and not move backwards after the beat again.
    I’m this far with the expression already:
    temp = transform.position[0];
    temp1 = transform.position[1];
    temp2 = transform.position[2]+time*20;
    [temp , temp1 , temp2]
    Help is appreciated.
    -Ole
    Ole Peters replied 11 years, 1 month ago 2 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    August 8, 2015 at 6:05 pm
  • Ole Peters
    August 8, 2015 at 6:21 pm
    Since I don’t really want to put the whole thing in a Pre-comp and use time remap I thought it might work with the camera too.
    I get an error message saying:”Can’t appear on the left hand side of assignment, because it’s read-only”
    Please note, I’m kind of new to expression writing so I don’t know how I should alter the expression on the site.
    Ole
  • Dan Ebberts
    August 8, 2015 at 6:34 pm
    Try changing the last line to this:
    value + [0,0,accum*mult]
    You’ll probaly also want to increase the value of the mult variable (I’d start with 100).
    Dan
  • Ole Peters
    August 8, 2015 at 6:48 pm
    It works fine so far, but it still moves backwards after it moved forward.
    Any ideas?
  • Dan Ebberts
    August 8, 2015 at 8:51 pm
    Are you animating the camera in some other way as well?
    Dan
  • Ole Peters
    August 8, 2015 at 10:30 pm
    The Expression I use is
    So the Camera is moving forward on the Z axis.
    I added your expression like this:
    temp2 = transform.position[2]+time*20+YourExpression;
    Assuming that it’ll accelerate the Camera on a beat of the Audio Amplitude.
    Ole
  • Dan Ebberts
    August 8, 2015 at 11:16 pm
    This should be all you need:
    z = time*20;
    spd = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    mult = 100;
    n = spd.numKeys;
    if (n > 0 && spd.key(1).time < time){
    accum = spd.key(1).value*(spd.key(1).time - inPoint);
    for (i = 2; i <= n; i++){
    if (spd.key(i).time > time) break;
    k1 = spd.key(i-1);
    k2 = spd.key(i);
    accum += (k1.value + k2.value)*(k2.time - k1.time)/2;
    accum += (spd.value + spd.key(i-1).value)*(time - spd.key(i-1).time)/2;
    }else{
    accum = spd.value*(time - inPoint);
    value + [0,0,z+accum*mult]
    Again, you may want to adjust the value of mult (in the 3rd line)
    Dan
  • Ole Peters
    August 8, 2015 at 11:54 pm
    Works like a charm! You are awesome Dan!
    I kind if feel like a douche now, I forgot to say that a little treshold in the expression would be good. Is it possible to add it in the expression?
    I’m really sorry, I forgot it completely.
    Ole
