Activity Forums Apple Final Cut Pro Legacy Camera won’t preview through firewire
  • Camera won’t preview through firewire
    Posted by Mark Gringo on January 7, 2006 at 9:52 pm
    final cut pro 5 is not recognizing my camera via firewire. i have tried deleting my quicktime receipts, trashing prefrences but nothing works. funny thing is… is that i can control my camera (stop, play, rew). I have video setting set at Easy Set Up DV – NTSC.
    what gives?
    “you wanna toe? I can get you a toe… I’ll get you a toe by this afternoon–with nailpolish…”
    – Walter
    Mark Gringo replied 20 years, 8 months ago 3 Members · 6 Replies
  • Bouncing Account needs new email address
    January 7, 2006 at 10:03 pm
    Try looking here:
    https://docs.info.apple.com/article.html?artnum=301852
    This seems to be the answer to many of these kind of problems.
    Worth a shot.
  • Mark Gringo
    January 7, 2006 at 10:10 pm
    i tried that already… and still nothing.
    – Walter
  • Rob Forsythe
    January 7, 2006 at 10:12 pm
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    d. Being able to capture from a FW device.
    If working this list doesn’t cure the problem… you may have a serious PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Make sure you have chosen FW output for A/V:
    Final Cut Pro (menu) > Audio/Video Settings… >
    Video Playback: Apple FireWire NTSC (720 x480)
    Audio Playback: FireWire DV
    11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    15. Important: Quit FCP, then Restart FCP.
    16. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
  • Mark Gringo
    January 8, 2006 at 3:38 pm
    still no go… i even tried a clean FCP install. ichat sees my gl-1 just fine. i am stumped.
  • Mark Gringo
    January 8, 2006 at 3:43 pm
    In my “Audio Video Settings” i get —> Video Playback: [Missing] Apple Firewire NTSC (720×480)
  • Mark Gringo
    January 8, 2006 at 7:42 pm
    Now it’s working again. After I reinstalled quicktime 7.
