Activity › Forums › Adobe After Effects › Camera won’t follow the Motion Path correctly
  • Camera won’t follow the Motion Path correctly
    Posted by Terry Stone on February 6, 2008 at 4:17 am
    Hi everyone
    I have spent a week on this and I am very stuck and frusterated. I’d greatly appreciate any help anyone can offer me.
    I am trying to have a camera follow the path of a growing line. The 3d comp is already set up and I have alreadyanimated the line. Now I’d like to create a motion path so that the camera can follow the line as it grows. Also, the line does make several sharp turns as it goes.
    So I found this post: https://forums.creativecow.net/readpost/2/925765
    and followed the instructions – i used the method of creating a mask with a pen tool. As a result the camera successfully follows the path that i created for it up until it is time to turn to a different direction. So in other words, at the point that the camera should turn and continue following the line along the path, the camera just stops.
    Any help would be greatly appreciated!!!!
    Thank you so much
    Terry Stone replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
