Activity › Forums › Adobe After Effects › Camera Twitch/Shake Colour transition
Posted by Tom Getty on April 28, 2012 at 4:06 pmHi,
I’m fairly new to after effects, and have recently seen a technique that i cant quite replicate. So, i was wondering, does anyone know how to do a transition between shots in after effects, it sort of jerks the camera and shakes into the next shot. It can be seen in this video at 5.58mins and various other points throughout.
Thanks 🙂
Tom Getty replied 14 years, 4 months ago 2 Members · 3 Replies -
Tom Getty
April 28, 2012 at 6:50 pmForgot to say, heres the link…
https://www.youtube.com/watch?v=fPAoHYhj6TA
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Cuevas
April 29, 2012 at 2:34 pmIt looks like there was some time-remapping, perhaps multiple shots that the editor was transitioning to/from in the square-crow sequence that can be executed by precomping the layers and dissolving between shots. As far as the effects though you can accomplish this pretty easy.
Add CC Motion Tile to your layer and check the Mirror Edges option. Add a shift Channels effect. Now duplicate your layer twice, for a total of 3 layers. You want to make each layer display only one color channel. So for the top layer -> Shift Channels change the “Take Green/Blue” to Full off. Do this for all three layers so you have a Red/Green/Blue layer. Now change all the layers tranfer mode to screen.
Finally just animate the Motion Tile center for each layer very quickly. Add a start keyframe, move 5-6 frames forward and add an end keyframe. Now in the middle add a keyframe that moves the video. Do this for all 3 layers, but don’t move them all the exact same.
You might also add some motion blur to taste.
I made a simple example project in case my explanation was unclear: 4050_rgbsplitfolder.zipJohnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Tom Getty
April 30, 2012 at 8:25 pmThank you so much, that is exactly the effect i was trying to achieve. Really appreciate you putting in the time to help, this will definitely come in handy!
