Activity Forums Zaxwerks Camera Tracker CS6 ProAnimator
  • Camera Tracker CS6 ProAnimator
    Posted by Robert Mcgowan on June 28, 2012 at 4:05 pm
    Hi There
    Wondering if anybody can help me
    I’m working with the new CS6 After Effects on MAC
    I have some footage to be tracked I apply the tracker and get the option to add a solid or text layer etc…
    Choose solid and apply ProAnimator, I want 3D text to move with the camera – however when I hit the 3D layer button my ProAnimator text goes 2D with no depth to it?
    What can de done here are there any solutions?
    Proanimator is far better at 3D text, but I can’t find a way round this
    bob
    Robert Mcgowan replied 14 years, 2 months ago 2 Members · 4 Replies
  • Edward Wu
    June 28, 2012 at 7:04 pm
    Hi Robert,
    With ProAnimator version 6, you’ll have the option to track your 3D Objects to any After Effects 3D Layer. You’ll be able to track your ProAnimator text to the After Effects layer that contains the tracking data (or any other 3D Layer) and the text will move along nicely. Along with Layer Tracking, we have also added our new Ray Tracer Renderer. With this, you’ll be able to create Ray-Traced Reflectivity, Shadows, Refraction and Ambient Occulusion. This will allow you to create reflective surfaces that reflect other objects, shadows that fade with distances, and highly realistic glass materials. In addition, with ProAnimator 6, you’ll be able to take any object or logo, and break them into little pieces. It’s going to be a very fun release.
    We’re looking to release the plug-in early next week. Once the release is available, you’ll receive an e-mail notification.
    In the mean time, with ProAnimator version 5, what you can do is first have the After Effects Comp Camera be tracking the footage. Then enable the option “Use Comp Camera” in the ProAnimator controls. By using the Comp Camera, your ProAnimator text will change in perspective with all the camera changes that it tracked to the footage.
    Hope this helps.
    Best,
    Edward
  • Robert Mcgowan
    June 28, 2012 at 8:22 pm
    Thanks for the info Edward – I look forward to seeing the new plug in, sounds exciting –
    Just for the moment I’m still struggling with the comp, you say use the camera option in ProAnim
    should i switch the 3D off? or keep it a 2D layer?
  • Edward Wu
    June 29, 2012 at 6:36 pm
    Hi Robert,
    Keep the ProAnimator Layer 2D. The ProAnimator plug-in should always be applied to a Color Solid that is Comp-Sized.
    Hope this helps.
    Best,
    Edward
  • Robert Mcgowan
    June 30, 2012 at 2:56 pm
    I’m sure others would be interested as well Edward, could you do a tutorial for the this ?
    I’m still not being able to control the text as I should –
    its goes really small and is hard to modify whilst shifting along the X plane — I believe its something to do with the 3D/2D space
    fingers crossed
    robert
