Activity › Forums › Adobe After Effects › Camera Tool Problems!
  • Camera Tool Problems!
    Posted by Aaron Taylor on July 22, 2011 at 11:28 pm
    I am having a problem with the camera tool. I keep getting this weird distortion field or ‘fuzz’ on some of my recent comps. I’ve never had an issue before. The distortion last for a second then goes away. I can’t seem to get rid of it.
    What am I doing wrong? 🙁
    Thanks in advance..
    Cheers!
    Aaron Taylor replied 15 years, 2 months ago 2 Members · 5 Replies
  • Brian Charles
    July 23, 2011 at 12:03 am
    Is this while you’re working or when you render?
    If it’s while you’re working check your Fast Preview Preferences, you may be seeing Adaptive Resolution or openGL artifacting.
  • Aaron Taylor
    July 23, 2011 at 12:05 am
    The problem is while I render.
  • Brian Charles
    July 23, 2011 at 12:29 am
    Could you post a screen shot of the both distorted and not distorted.
    Difficult to diagnose from your description.
    Effects, lights anything else that might be causing the distortion?
  • Aaron Taylor
    July 23, 2011 at 12:46 am
    I wish I could post a picture… but unfortunately I’m home now and the problem happened at work 🙂 I won’t be able to post anything until Monday. The best way I can describe the distortion is…… well it’s like someone added a layer of film grain.
    I tried turning off the light layer and even changing the camera type, but i kept running into the problem. I am using a 4k sized background in an hd comp. (could not find anything smaller)
  • Aaron Taylor
    July 23, 2011 at 11:33 am
    I decided to go back to work after all. I figured out the problem.
    I turned off the ‘depth of field’ option in the camera. it corrected the distortion problem
