Activity Forums Maxon Cinema 4D camera to spline-skips
  • camera to spline-skips
    Posted by Danny Perez-triana on July 10, 2018 at 6:38 pm
    hey everyone, I’m new to c4D and have been trying to animate a camera along a circular spline. I’m able to set the spline as the path, but every time I do a preview, render, the object I’m “shooting” skips and changes position.
    -I Don’t see any key frames for the object or subdivision surface.
    -There are no key frames when it jumps/skips on the timeline.
    any help here would be appreciated,
    hope all is well
    Ignacio
    PS: I’m using C4D version studio R18. I have a video of the preview but can’t upload it to CC as it’s 3mb.
    Jim Scott replied 8 years, 2 months ago 3 Members · 5 Replies
  • Brian Jones
    July 10, 2018 at 7:18 pm
    can you post the c4d file?
  • Danny Perez-triana
    July 10, 2018 at 11:21 pm
    here is the project file. let me know if you are able to download? the CCow interface is a lil confusing as to how you attach files.
    12520_fabrictest1.c4d.zip
    hope all is well,
    Ignacio
    dip
  • Jim Scott
    July 11, 2018 at 12:17 am
    Hi Ignacio,
    The target object isn’t moving, the camera is flipping its heading at the 90 and 270 positions of the circle spline. If you deactivate your camera so that the default camera is being used, and reframe the scene so that you see the orbiting camera and its spline path from off to the side, you will see its heading flip 180 degrees as it passes the 90 and 270 degree positions of the spline (25% and 75% positions on the path). To correct this, add the same target object into the “Up Vector” slot of the tag’s properties.
    Also, the easiest way to upload files is to simply drag the file into the message window.
    July 11, 2018 at 1:31 am
    Thanks Jim! very nice of you. I really appreciate it. I don’t think I would have ever figured that out.
    and thanks for the tip re attachments. my bad.
    hope all is well,
    Ignacio
    dip
  • Jim Scott
    July 11, 2018 at 1:53 am
    You are very welcome. I’m glad I was able to help.
