Activity › Forums › Apple Final Cut Pro Legacy › Camera that works natively with FCP
Posted by Carlos Aguilar on January 10, 2013 at 1:57 amI’m trying to buy an HD camera in the range of $1,000 to 1500 that works perfectly with FCP.
https://losangeles.craigslist.org/sgv/pho/3530486265.html I like that Panasonic but the problem is that AVCHD files are not supported in FCP and they have to be transcoded in clipwrap I understand. Do you guys have any suggestions for good cameras that I can just transfer the files directly without transcoding?
Thank you
Shane Ross replied 13 years, 8 months ago 5 Members · 8 Replies -
Shane Ross
January 10, 2013 at 2:06 amThere is only one….but it is $2500. The JVC GY-HM150. That camera shoots to native XDCAM .MOV files that can be directly edited in FCP.
https://pro.jvc.com/prof/attributes/features.jsp
Every other camera shoots footage that needs to be converted. Now, there are some, like the Panasonic HPX-170, HVX-200 (P2 cameras) that shoot DVCPRO HD…that footage won’t require “transcoding,” but you still need to use Log and Transfer to re-wrap the footage from MXF to MOV. But that is a process that is fast…as fast as copying the data from the card to the hard drive. But again, those are over $1000.
You won’t find a camera that fits your criteria. And the one you mention doesn’t require ClipWrap…FCP’s Log and Transfer will work with that. This is the workflow for most tapeless cameras:
https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Carlos Aguilar
January 10, 2013 at 2:09 amHi Shane
Thank you so much for your quick response. I heard Adobe Premiere works natively with AVCHD, do you recommend that or should I try to stick with FCP?
I’ll watch the video asap, thank you so much!
Rafael Amador
January 10, 2013 at 2:10 amThere is no file format from any camcorder that you can drag and drop directly to FC.
AVCHD and friends (H264), needs transcoding.
Probably the most FCP friendly are the XDCAM based formats. They don’t need transcoding, but re-wrapping as QT.
SONY, JVC and Canon have camcorders based on those codecs, but I don’t know if there is any on your price range.
Have a look to JVC.
rafael -
Shane Ross
January 10, 2013 at 2:30 amAVCHD is a VERY complex and demanding format. Working with it natively requires a LOT of power. Top of the line computer with lots of RAM, fast fast processors, and a really good graphics card that can enable CUDA and the mercury engine. Without that, it’ll be like driving in thick mud. AVCHD is a bear of a format. Even when I use Premiere I transcode before I work with it. To ProRes via the PRELUDE app.
Ask anyone who uses Premiere. Perhaps if your project is small, and not a lot of footage. But long form…best to transcode.
Shane
Little Frog Post
Jeff Meyer
January 10, 2013 at 3:47 amShane mentioned the JVC 150 above, which does shoot Quicktimes that work with FCP – no transcode needed.
Carlos Aguilar
January 10, 2013 at 3:52 amI watched your video Shane, you explain everything really well. It seems fairly easy to transcode AVCHD to Pro Res 422? Just to make sure, can you let me know some AVCHD plug-ins for this here?
I also want to get some good lavalier mics, omni-directionals and cardioids. Do you guys recommend any?
Kent Beeson
January 10, 2013 at 6:24 amWould the new top of line 27″ iMac handle avchd raw footage natively in Fcp x or even fcp 7?
K
http://www.effective-video.com -
Shane Ross
January 10, 2013 at 8:53 am[Kent Beeson] “Would the new top of line 27″ iMac handle avchd raw footage natively in Fcp x or even fcp 7?”
I cannot comment as to FCX, but I hear it works OK. FCP 7 on the other hand, that doesn’t edit AVCHD native.
Shane
Little Frog Post
