Activity Forums Maxon Cinema 4D camera target and animation problem
  • camera target and animation problem
    Posted by Richard Quinn on March 17, 2009 at 12:03 am
    I have a three problems with a part of an animation I am doing, and would be grateful as always for any help.
    1. I have followed advice in a previous thread on the forum about making a camera follow an object using null objects and the target tag. I can’t for the life of me figure out why the camera is still not following the bus?
    2. I used expresso to get the rear of the bus to follow the front. The bendy middle section of the bus seems to come away from the bus when it is moving? How can I fix this?
    3. I cannot seem to slow the bus down at the end of the path. I have tried adding more points and setting the spline’s intermediate points to neutral but this seems to make the buses bending middle section dissapear?
    Here is the project file
    Cheers,
    Rich
    Richard Quinn replied 17 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 17, 2009 at 2:43 am
    1. the camera doesn’t follow the bus because the target tag is attached to the camera null so the null is targeted but the camera isn’t lined up with the null’s z-axis – easiest thing to do is put the target tag on the camera directly. Next problem is you are targeting the bus null, which does not move. Target the front or back of the bus instead (you can’t target the joint either since it is also in a null which does not move)
    2. the joint section jumps because the Constraint tags which control the location of the Joint splines are being evaluated after the align tags so the bus parts move but the joint bits don’t move until later. Increase the priority in the Constraint tags to something greater than the priority in the Align tags (1 is enough)
    3. you are controlling the position of the bus by the Position in the Align tag of the front part of the bus. You can’t add more points because the spline is remains the same length. You could add more keyframes to the Position parameter but it’s really hard to do that smoothly, it’s easiest to use few keyframes but to control the speed of the bus between the keyframes with the F-Curve.
    Check it out
  • Richard Quinn
    March 17, 2009 at 6:51 am
    Brian you are a superstar…….thanks so much!!! I can put some of my hair back on my head now!!!!!!
