Activity Forums Adobe After Effects Expressions Camera Swap Script Trouble
  • Camera Swap Script Trouble
    Posted by Mark Allen on January 26, 2009 at 12:52 am
     // create undo group
      app.beginUndoGroup("Swap Camera Position");
      // select the active item in the project window
      alert("Make sure you have a comp selected and it is has a camera called Camera 1");
      // variable for the comp
      var activeComp = app.project.activeItem;
      var poiX = activeComp.layer("Camera 1").transform.pointOfInterest[0];
      var poiY = activeComp.layer("Camera 1").transform.pointOfInterest[1];
      var poiZ = activeComp.layser("Camera 1").transform.pointOfInterest[2];
      var camX = activeComp.layer("Camera 1").transform.position[0];
      var camY = activeComp.layer("Camera 1").transform.position[1];
      var camZ = activeComp.layer("Camera 1").transform.position[2];
       activeComp.layer("Camera 1").transform.position[0] = poiX;
       activeComp.layer("Camera 1").transform.position[1] = poiY;
       activeComp.layer("Camera 1").transform.position[2] = poiZ;
       activeComp.layer("Camera 1").transform.pointOfInterest[0] = camX;
       activeComp.layer("Camera 1").transform.pointOfInterest[1] = camY;
       activeComp.layer("Camera 1").transform.pointOfInterest[2] = camZ;
      app.endUndoGroup();
    Okay – I’m new to writing scripts/expressions.. but I’m trying. I wanted a script that would swap the position and pointofinterest of my camera.
    At first I couldn’t get it to recognize the layer I had selected, but I think I got it to recognize a layer named Camera 1 at least, so I went with that – but… it doesn’t do anything. I know I must be assigning the position value incorrectly but after about six variations and a long internet search, I’m out of ideas… help appreciated, thank you.
    Mark Allen replied 17 years, 7 months ago 2 Members · 3 Replies
  • Mark Allen
    January 26, 2009 at 1:06 am
      var poiZ = activeComp.layer("Camera 1").transform.pointOfInterest[2];
       activeComp.layer("Camera 1").transform.position.setValue([poiX, poiY, poiZ]);
       activeComp.layer("Camera 1").transform.pointOfInterest.setValue([camX, camY, camZ]);
      app.endUndoGroup();
    Quick Update – I think this is maybe how setting the value is done, but it does not think my position information is a valid float now.
  • Dan Ebberts
    January 26, 2009 at 1:37 am
    Hi Mark,
    This should work:
    app.beginUndoGroup(“Swap Camera Position”);
    alert(“Make sure you have the camera selected in the active comp”);
    var camLayer = activeComp.selectedLayers[0];
    var poi = camLayer.transform.pointOfInterest.value;
    var camPos = camLayer.transform.position.value;
    camLayer.transform.position.setValue(poi);
    camLayer.transform.pointOfInterest.setValue(camPos);
    app.endUndoGroup();
    Dan
  • Mark Allen
    January 26, 2009 at 2:02 am
    Thanks, Dan. I will look through this to learn a bit.
    Seemed like a good script to learn from while being sort of useful (unless you count the time it took me trying to figure out how to write it. 🙂 )
