Activity Forums Adobe After Effects Camera Stabalizing & Match Moving
  • Camera Stabalizing & Match Moving
    Posted by Josh Brine on November 20, 2012 at 8:58 pm
    I have some test hand held footage i shot, its a bit jerky,
    shot on a 5d at a higher shutter speed to see if it helps with tracking.
    anyway, i have a question,
    if i took this footage into AE, stabalised it, and then exported the stabalised version into my match mover (blender) would it be better? is this a workflow used?
    or should i get it near finished then stabalize?
    just looking for some pointers on workflow.
    thanks
    Josh
    Roland R. kahlenberg replied 13 years, 9 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    November 21, 2012 at 1:57 am
    Your biggest worry would be with any rolling shutter artefact. Remove that if it exists (hopefully you shot a grid pattern to guide you).
    Once that is done, it doesn’t really matter if you stabilize or matchmove first. In fact I would rather matchmove first since stabilization may introduce slight warping which will preclude any decent matchmove solve.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Josh Brine
    November 21, 2012 at 4:57 pm
    I actually dont have a grid, still working out the ins and outs of shooting this stuff.
    I have seen a grid used for correcting/matching lens distortion, is this the same grid? and is it specific?
    November 22, 2012 at 2:36 am
    [Josh Brine] “I have seen a grid used for correcting/matching lens distortion, is this the same grid?”
    YUP!
    [Josh Brine] “is it specific?”
    I don’t understand what you mean by “specific”. You should be able to create one from a spreadsheet. Print it out and then paste it onto a board.
    BTW, mochaAE/Pro 3.1 has a new AE plugin that caters to lens distortion issues. More info here.
    HTH
    RoRK
