Activity Forums Adobe After Effects Camera Shake Problem?
  • Camera Shake Problem?
    Posted by Kyle Sowden on July 25, 2011 at 11:51 pm
    Okay, so i’m following this tutorial > https://www.videocopilot.net/tutorials/procedural_crumble/
    And as you can see, his version has a camera shake using the wiggle, but he doesn’t actually go over the wiggle in the tutorial.
    And because I have so many layers, and he has an extra pre-comp called “shake” that he doesn’t explain, I have no idea where to add the wiggle.
    Could somebody please give me a rundown on how I would add the camera shake like in this tutorial?
    Walter Soyka replied 15 years, 1 month ago 3 Members · 5 Replies
  • Tudor “ted” jelescu
    July 26, 2011 at 7:28 am
    The wiggle should be applied to the camera position or to the Null/Nulls that control the position if you use a camera rig.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kyle Sowden
    July 26, 2011 at 7:48 am
    I have tried adding a null and then moving the camera around but the whole thing just stays still?
    Do I need to parent the null to something, or something along those lines? :s
    July 26, 2011 at 7:59 am
    Here’s a good tutorial on building a camera rig:
    https://maltaannon.com/articles/after-effects/simple-camera-rig/
    And here’s a goog one for camera shake:
    https://www.videocopilot.net/tutorials/camera_shake_with_wiggler/
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kyle Sowden
    July 26, 2011 at 8:11 am
    I’ll check those out now, thanks!
  • Walter Soyka
    July 27, 2011 at 1:14 am
    I described how to do camera shake with a null and the wiggler [link] on this forum a few weeks ago.
    Even if you’re using a camera rig, I recommend using the wiggler on a null, then parenting the rig to the null. This will give you a lot more flexibility if you need to move the wiggled keyframes later in the animation.
    Walter Soyka
