Camera shake effects
Posted by Frenchie29 on August 2, 2007 at 3:16 amHi any idea how to create a camera shake effect with Vegas 7? I tried with event pan/crop option but doesn’t work too good… a bit to smooth , not jerky enough.
Frenchie29 replied 19 years, 1 month ago 3 Members · 8 Replies -
Edward Troxel
August 2, 2007 at 1:24 pm -
Edward Troxel
August 2, 2007 at 3:51 pm -
Frenchie29
August 2, 2007 at 7:00 pmI tried to install but it’s asking me for the Vegas 5 folder I use Vegas 7 directed it to the Vegas 7 folder and same error
Edward Troxel
August 2, 2007 at 8:04 pm -
Mike Kujbida
August 2, 2007 at 10:23 pmTry this suggestion from a poster on the Sony Vegas forum.
Extract the file to: C:\Program Files\Sony\Vegas 7\Script Menu
You should see a folder in the Script Menu entitled “Vegas Quake.”
You can either go to “Tools-Scripting-Vegas Quake” and execute the script, or go to “Options-Customize Toolbar” and add the Vegas Quake icon to your toolbar (which I have done, it’s an italic caps Q in a shaded blue square.
Either way, select a timeline track and region, then run the script or click the icon. A GUI will give you the various options, click OK and off you go.
Frenchie29
August 2, 2007 at 11:30 pmHere’s what I get when I either use it in the toolbar or trough the script menue
C:\Program Files\Sony\Vegas 7.0\Script Menu\VegasQuake.js(4) : Type name expected
C:\Program Files\Sony\Vegas 7.0\Script Menu\VegasQuake.js(4) : Type ‘VegasQuake.VegasQuake’ could not be found, is an assembly reference missing?
