Activity › Forums › VEGAS Pro › Camera shake
  • Mike Kujbida
    June 9, 2009 at 5:29 pm
    Assuming you mean vegas Pro 8, yes.
    New Deshaker for Sony Vegas
  • Jeff Mcguire
    June 9, 2009 at 5:50 pm
    Thanks Mike
    I found and installed it. Just need to know how to access it from a scene.
    Or do I open a program and import the scene in?
    Jeff
  • Mike Kujbida
    June 9, 2009 at 6:23 pm
    Jeff, I haven’t used this software yet but, from the description on the site I linked to, it’s designed to be a script/extension.
    New Deshaker for Sony Vegas Pro 8.0 may be installed as either a Vegas Script or Vegas extension.
    The installer defaults to installing as a script in the folder C:Program FilesSonyVegas Pro 8.0Script Menu but that may be overridden to place it in your My DocumentsVegas Application Extensions or My DocumentsVegas Script Menu folder for example.
    New Deshaker for Sony Vegas 7.0 is installed as a Vegas Script.
    The installer defaults to installing as a script in the folder C:Program FilesSonyVegas 7.0Script Menu.
    The VirtualDub self-extracting archive defaults to installing in the C:Program FilesVirtualDub folder.
    The default setup for New Deshaker for Sony Vegas also expects VirtualDub to be in that folder so that will also need to be changed if the default is overridden.
  • Jeff Mcguire
    June 9, 2009 at 7:05 pm
    Mike
    I managed to launch VirtualDub. Ofcourse it wouldn’t accept my “Upshifted” file (.m2t)
    Jeff
  • Jeremy Rasnic
    June 9, 2009 at 7:26 pm
    Hi Jeff,
    I use this (and have used it when you had to hand code the perimeters in vdub for it to work). With the new deshaker, you simply call it from the script folder in Vpro8 after you have selected the event to “deshake”. Make sure it is not a lengthy selection as I find that it works better with smaller-sized events. Once it completes, you will see it has replaced the event on the timeline. If you don’t like how it turned out you can change the parameters or simply right click the event and choose the other take- the other take will be your original event.
    Hope this helps.
    j razz
    https://www.jrazzcreations.com
  • Jeff Mcguire
    June 9, 2009 at 7:44 pm
    Jeremy
    How do you “call it from the script folder”? I have never used scripting manually.
    Jeff
  • Jeremy Rasnic
    June 10, 2009 at 4:02 am
    Just click on it. You must install Virtual Dub and place the New Deshaker script in the scripts folder… but now that I think about it, it comes with in installer that does all of this for you.
    Can you verify that you installed it correctly and that you have both vdub and the New Deshaker installed?
    j razz
  • Jeff Mcguire
    June 10, 2009 at 12:17 pm
    Yes, I managed to start Vdub from the program level, but I don’t know how to verify New DeShaker. I know that it did auto-install
    Jeff
  • Jeremy Rasnic
    June 16, 2009 at 9:12 pm
    Jeff, I’m losing you- maybe I can remote in and see what is going on for you. Perhaps tomorrow morning? I am on Central time so right now it is 4.10pm where I am at. Shoot me your email address (or an email from your email address) and I will send you a code for me to remote in with and maybe we can figure out what is going on. It is only valid for 20 minutes. Perhaps around 9.30am we can start the remote?
    j razz
  • Jeff Mcguire
    June 22, 2009 at 3:44 am
    Jeremy
    Sorry for the delay. I was on a trip.
    I would like to resolve this but must get through this week.
    Jeff
