Activity › Forums › Boris FX Particle Illusion › Camera shake
Camera shake
Posted by Jamie Young on July 15, 2009 at 3:11 pmI only use PI for my effects. I was wondering if anyone knows a way to simulate a camera shake.
please and thank you.
Jamie.Theo Van laar replied 17 years, 1 month ago 4 Members · 4 Replies -
Alan Lorence
July 16, 2009 at 2:19 pmYou can use “record position” to manually move around an emitter, then export that position data to the clipboard. Then you can select the “Layer Offset” and import the position data from the clipboard and the layer will now have this “shaking” motion.
BUT… any background images won’t be affected by this. So if you want to shake your footage and your effects, you’ll need to use another application most likely.
Alan.
Theo Van laar
July 19, 2009 at 2:36 pmA good program to obtain the camera-shake is VideoShaker from Prodad.
https://www.prodad.de/gb/mercalli_std_details.html
Theo
Peter Friend
August 12, 2009 at 9:13 pmThe web site says it’s included in the demo version of Mercalli, but also notes this demo version puts a red cross on output – does anyone know whether the red cross appears in the Video Shaker output?
Theo Van laar
August 16, 2009 at 12:50 amI only can tell you that the red cross will not appear in the registrated version of VideoShaker.
Theo
