Activity Forums Sony Cameras camera settings for KiPro
  • camera settings for KiPro
    Posted by Ron Pestes on December 15, 2010 at 6:41 pm
    Hi Guys,
    Does it matter what the frame rate settings are set in the camera when recording to a KiPro or does the camera output the same signal regardless and you just set the KiPro for what you want? Thanks for your help.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Ron Pestes replied 15 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Palmer
    December 15, 2010 at 7:57 pm
    I know my Nano recognizes the signal it receives and I’m sure it is the same for the KiPro. If you choose 24p format then you can set the SDI output for either 60i or 24p on the EX cameras.
    Good Luck
    Michael Palmer
  • Daniel Doherty
    December 16, 2010 at 1:31 am
    Yep, Michael is right. In the EX3 menu go to Genlock and choose either 60i or 24p. That will set your hdsdi out.
  • Ron Pestes
    December 16, 2010 at 1:39 am
    OK, thanks guys.
    Sony EX-3
    MacBook Pro
  • Ron Pestes
    December 16, 2010 at 1:44 am
    I was just looking at the menu and that option is greyed out. How do I turn it on?
    Sony EX-3
    MacBook Pro
  • Michael Palmer
    December 16, 2010 at 4:10 am
    Try setting the camera to 24p format then look at that setting, or make sure you have a newer firmware.
    Good Luck
    Michael Palmer
  • Don Greening
    December 16, 2010 at 4:18 am
    [Michael Palmer] “Try setting the camera to 24p format then look at that setting, or make sure you have a newer firmware.”
    Yeah, that’s what you have to do so it’s not grayed out: Set your recording format to 24p and then in genlock you can choose between 60i or 24psf (progressive segmented frame).
    – Don
    Don Greening
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Ron Pestes
    December 16, 2010 at 6:00 am
    Got it. Why does this have anything to do with genlock? I feed the SDI signal to a Panasonic digital switcher and don’t need genlock. We mix 3 cameras this way with only the SDI cable.
    Sony EX-3
    MacBook Pro
