Activity › Forums › Panasonic Cameras › Camera settings for :30 with Avid MC 3.0
  • Camera settings for :30 with Avid MC 3.0
    Posted by James Laruffa on April 24, 2009 at 2:56 am
    Hello,
    I will be shooting a :30 spot on Saturday using an AG-HVX200A and editing on Avid Media Composer 3.0.
    The spot will only air on cable and will be SD in 4:3 format. The delivery is going to be a mini-dv tape in DVCPRO or DVCPRO50 format.
    I need to know what setting to work with for the camera and the Avid.
    I think 720p is the way to go, and since it is not going to film, should I shoot at 30P instead of 24P?
    As far as the Avid goes, if I shoot at 30P, the settings look like it will be 720P/30PN. My concern, according to Avid’s specs, is that the resolution will be DVCPRO HD (100). I am not sure if this will work…
    Any advice on this will be appreciated.
    I really want the best quality possible, based the above specs…
    Jim
    James Laruffa replied 17 years, 5 months ago 2 Members · 2 Replies
  • John Fishback
    April 24, 2009 at 5:43 pm
    The camera will shoot DVCPro 50. If that’s the delievry format why not just shoot that. Then you avoid having to convert HD to SD. I know the camera will record DVCPro 50 to a P2 card, but I don’t know if it will record it to tape.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • James Laruffa
    April 25, 2009 at 4:13 am
    Thank You John… I appreciate the advise.
    Jim
