Activity Forums Panasonic Cameras Camera Settings – Are you able to view in VTR ?
  • Camera Settings – Are you able to view in VTR ?
    Posted by Chris Lucey on July 13, 2007 at 9:40 am
    I shot a fast motion sunset in 24PA. I believe i used a SLOW shutter speed (6P). Unfortunately i did not write it down. Is there a way to determine what setting i actually used ?
    I was told in Camera Settins under Display settings when switched to on would show the settings in the bottom right hand corner and they would show up when in playback mode.
    Unfortunately i cannot seem to make it work. Does or can anyone help me figure it out.
    Noah ?
    Steve Wargo replied 19 years, 1 month ago 5 Members · 5 Replies
  • Tim Scarpino
    July 13, 2007 at 1:08 pm
    Are you seeing ANY on-screen settings in the playback mode?
    Tim Scarpino
  • Noah Kadner
    July 13, 2007 at 6:43 pm
    I’m not 100% sure but I don’t think shutter settings are recording to tape.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Lance The tech
    July 15, 2007 at 5:03 am
    Unfortunately the only data that is recorded in DV without your knowing it is time and date. This you can display or switch off during playback. There is no recorded data on the mode you shot in. Time to change to P2!!!
  • Chris Lucey
    July 16, 2007 at 5:58 pm
    Doh !
  • Steve Wargo
    July 24, 2007 at 12:46 am
    If you guys would use the tapes with the memory, you would have all of that info on your tapes, ready for display. That’s the price you pay for buying the cheap stuff and not using tape decks.
