Activity Forums Adobe After Effects Camera Rotation
  • Camera Rotation
    Posted by Kuljeet Singh on March 16, 2016 at 12:00 pm
    hello,
    Please help to solve camera rotating issue. Every time i rotate the 3D layers with camera layer, it rotates the layer around the world axis rather than the my layer axis. Please help me to fix this where i’m doing wrong.
    Kuljeet Singh replied 10 years, 6 months ago 2 Members · 2 Replies
  • Walter Soyka
    March 16, 2016 at 12:46 pm
    Rotating the camera should rotate the view of the scene, right? If you want to rotate layers about their local axes, you should transform the layers directly, not the camera.
    If I’ve misunderstood, perhaps a quick screen capture would be helpful in explaining what you’re seeing?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kuljeet Singh
    March 16, 2016 at 1:00 pm
    thanks for the reply,
    i’ve just changed the camera from one to two node camera & it just solved the issue.
