Activity › Forums › Adobe After Effects › Camera Projection with white edge?
  • Camera Projection with white edge?
    Posted by Ah Weii on November 14, 2015 at 4:44 pm
    guys i am new to camera projection, i have been trying this on after effects, now i tried to do multiple camera projection in after effects, which is using multiple freezed frame then combine as a clean plate, but i ran into a problem, when i put them all together, the white edges appears, why?
    Kalleheikki Kannisto replied 10 years, 10 months ago 2 Members · 4 Replies
  • Ah Weii
    November 15, 2015 at 4:43 pm
    help please =(……
  • Kalleheikki Kannisto
    November 15, 2015 at 5:19 pm
    So: How do you have it set up to begin with?
  • Ah Weii
    November 15, 2015 at 5:28 pm
    it’s a very normal camera projection method from after effects
    i have an original footage with a person standing slightly left of the white board.
    i 3d camera tracked and place three solid plate on font wall, left wall, and floor.
    then i duplicate the original footage and mask out the person, and place it on front of camera and light
    then i project it to the solid plates, to do the camera projection.
    but since the footage is a a nodal pan, the changes of perspective is more than slight
    so i gonna do 3 camera projection, but when i place three all together, i can’t see anything other than the first layer(means other two camera projection precom underneath cant be seen), then i decided to use play with luma matte and levels to create the alpha channel, so three layers can be seen,
    but the problem is when i reveal all three camera projection together, i saw the white edges, it’s weird…
    November 16, 2015 at 9:22 am
    I would do this as three images on three planes: Straighten the two walls and the floor into rectangular images in Photoshop, bring them into AE and turn the layers into 3D, align walls to floor.
    Or is there a reason to do this as camera projection?
    In terms of your original white edges problem, you could expand the matte edges. Or draw masks instead of using a key.
