Activity › Forums › Adobe After Effects › Camera position not rendering properly
  • Camera position not rendering properly
    Posted by Jacob Ferguson on July 30, 2015 at 6:19 am
    I do motion graphics and lyric videos in After Effects. I am currently working on a video that is causing a bit of a headache. If I work in one comp for too long, the camera position/point of interest starts to veer off course on parts that should have already been locked it. If try and pre render that area, even in a separate comp, the camera is still coming undone, and even MORE so if I try and run a script to bake the camera location. The camera has a inertia expression on the position and is parented to a null layer for a wiggle expression. I NEED the movement in the camera. Please help.
    Here are the same exact frames in my comp and after the render (or camera bake)
    Correct camera alignment: https://gyazo.com/42cf832436e9eec42d2efc72bd2425ac
    After render or camera bake: https://gyazo.com/90e0b265cafcf6dfccd3e5468ab300f1
    Walter Soyka replied 11 years, 2 months ago 2 Members · 1 Reply
  • Walter Soyka
    July 30, 2015 at 2:38 pm
    We’d need to see a screenshot of your entire UI at a minimum; this is impossible to troubleshoot from the output alone.
    Can you describe some more about how you’re animating the camera and what you’re doing when you notice that things are going off the rails?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
