Activity Forums Maxon Cinema 4D Camera position and cloth
  • Camera position and cloth
    Posted by Dan Roth on December 10, 2008 at 8:03 pm
    1. I would like to make my camera to keep rotating around a scene. i made a circle spline and aligned the camera to the spline but i can only go up to 100% in the position parameter and i need to keep circling, i.e go above 100%. i do not want to return to the beginning of the timeline because the camera only starts moving half way through the timeline.
    2. i have a cloth that i want to add more polygon subdivisions to increase its quality, but i cant seem to get the polygon number tag in the attribute manager. is it only available before you add the clothhide tag to it?
    Please advcice…
    Thanks in advance
    Dan
    Adam Trachtenberg replied 17 years, 8 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    December 10, 2008 at 10:37 pm
    1. Set up your align to spline animation for the correct speed to make one full rotation. Then select the align tag’s position track in the timeline, and in the attributes manager change the After parameter to “Repeat”. Now the camera will orbit repeatedly.
    2. I don’t know what you mean by “polygon number tag”. Generally you have to start over with a new cloth tag if you want to change cloth geometry.
