Activity Forums Adobe After Effects Camera Path + Point of interest
  • Camera Path + Point of interest
    Posted by Delete on February 18, 2007 at 7:12 pm
    My brain woke me up last night at 5a in reference to this idea… so, I’m turning to Bessy before I begin.
    I have a preset path I want to use for the “3d” camera position and another path I want to use for the point of interest position. I know from the podcast (thx Aharon) how to link shtuff to expression sliders, which is what I’d like to do with these position points and paths.
    Before I waste time on this personal learning project; Is it possible (y/n) to “slide” the position point from A to B along the path using a key-frame-able expression control? If the answer is yes, I’ll do it. If this seems like something I should have already known, then shoot me because I’ve been key-framing position points for cameras for about a year now. It seems there should be a better way.
    http://www.xonikz.com
    Aharon Rabinowitz replied 19 years, 7 months ago 4 Members · 4 Replies
  • Colin Braley
    February 18, 2007 at 9:42 pm
    Yes, it is possible to “slide” a layer along a path using expression controls. Here is some code to get you started:
    percentDone = thisComp.layer(“Controls”).effect(“Percent Done”)(“Slider”);
    //percentDone represents how far along the motion path the layer is
    nullPos = thisComp.layer(“Controls”).transform.position;
    //nullPos is the motion path we will follow
    currFrame = linear( percentDone, 0, 100, 0, timeToFrames( thisComp.duration ));
    nullPos.valueAtTime( framesToTime( currFrame ) )
    This code would take a layer, and slide it along the motion path of the layer named Controls. As the slider named “Percent Done” on the layer Controls varied form 0-100, the layer would move along the path.
    ~Colin
  • Sbrand
    February 19, 2007 at 3:37 am
    What is the advantage over simply copying the path into position keyframes of the layer?
  • Delete
    February 19, 2007 at 5:40 am
    I don’t know…
    um, I want to be able to do specific arcs, curves, etc. tracks in 3d similar to the film dolly/track setup concept. Having the positions expression controlled gives me the freedom to create the paths before hand in illustrator and import them for specific presets of camera motion; in essence, creating a true virtual set. I might be able to control a null on the “slider path” and parent the camera position to it, I suppose… Any thoughts? I go back to work tomorrow.
  • Aharon Rabinowitz
    February 19, 2007 at 1:06 pm
    I’d probably link the POI to a null with an expression, and just animate the null. You can get better control that way, because you can see the null even when the camera is not selected.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
