Activity Forums Maxon Cinema 4D camera path headache
  • camera path headache
    Posted by Richard Quinn on September 11, 2009 at 10:55 am
    I am hoping someone can help me with a camera path problem.
    I have a really basic animation of a camera moving down the front of a building.
    The camera path is bezier with uniform points.
    The camera is also targeted at a moving null object.
    The problem I have is when I render it out it seems to stutter. I have tried exporting as a quicktime 25fps with an animation codec. I have also exported the animation as a tif sequence and rendered it out of after effects but I cannot seem to get rid of the stuttering.
    Here is the project file and quicktime. If anyone could have a look that would be great.
    Cheers,
    Rich
    Richard Quinn replied 17 years ago 6 Members · 11 Replies
  • 11 Replies
  • Dave Glanz
    September 11, 2009 at 12:28 pm
    I used the CS tool EasyCam –https://circlesofdelusion.blogspot.com/
    My version (didn’t try rendering, but it plays smooth in the app)-
    https://www.daveglanzproductions.com/camera_path-rev.zip
  • Richard Quinn
    September 11, 2009 at 2:51 pm
    Hi Dave,
    Thanks for having a go with CS Tools easycam to try and rectify the camera problem. However I tried rendering your file and it still seems to stutter as it pans down the building?
    Here is the file to have a look.
    I rendered it out as a quicktime, 25fps and an animation codec.
    Any suggestions?
    Cheers,
    Rich
  • Richard Quinn
    September 11, 2009 at 2:56 pm
    Hi Dave,
    I also took the brick texture off in the render thinking that this maybe be causing the illusion of stuttering due to the lines. However even without a texture is still seems to be jerky?
    Its really puzzling?
    Cheers,
    Rich
  • Dave Glanz
    September 11, 2009 at 2:59 pm
    I guess I’d try changing the frame rate and QT settings to see if that makes a difference. I can think of no other reason why your renders would stutter.
  • Adam Trachtenberg
    September 14, 2009 at 8:53 pm
    I don’t see any stuttering. It could be that your video subsystem just can’t play back the uncompressed file smoothly. Try saving it out with h.264 or some other compression and see if that makes a difference.
  • Tim Shetz
    September 14, 2009 at 8:59 pm
    I rendered it off as QT with PhotoJpeg compression at 85%
    I still saw the “stuttering” but it seemed like it was an optical illusion. If you watch the windows, they seem to move smoothly. Hmmmm.
  • Richard Quinn
    September 14, 2009 at 9:36 pm
    Thanks guys,
    Yes, I am coming to the same conclusion that it may be an optical illusion having exhausted most avenues to go down??
    This is a real basic rig of a detailed model I have made. I decided to strip all lights off it and make a box model to see if I could get to the bottom of the problem but I am still puzzled.
    I am trying CS Easy Cam setup now exporting as a targa sequence to see if there is any difference.
    The final output needs to be 25fps. Would outputting the render at 50fps out of Cinema 4D have any benefit?
    Cheers,
    Rich
  • Martien Janssen
    September 15, 2009 at 2:33 pm
    Hi Richard,
    Your .mov file runs perfectly on my computer, but I’m having similar stuttering issues with my animations… Still looking for a solution myself, although I have found out converting the file to .avi or .mp4 solves it (but it’s not ‘the solution’ ofcourse).
    Goodluck
    Martien
  • Adam Trachtenberg
    September 15, 2009 at 3:01 pm
    I think it would help quite a bit if you added some motion blur, either in Cinema (Scene motion blur) or in post (RSMB).
  • Adam Trachtenberg
    September 15, 2009 at 3:54 pm
    The solution is to get a faster computer.
